GSXR_J
How Do I Tell Which Injector Plug Goes Where?
GSXR_J
Hey Guys, well im in the middle of a mi16 conversion on my 205 and bought a bx loom for the motronic conversion. The cars just about there, its turning over but not running. Ive checked the usual things i.e sparks from each plug, ht leads connections etc. The only thing im not sure about is the injector loom (unlabeled) -ive plugged it into the joining plugs from the main loom but when it comes to plugging each one onto each injector plug im not sure if they are in the right order. I cant see any numbers (i.e 1, 2, 3, 4) that relate to each one on each plug which has two black wires on each plug, im just wondering if any one knows of a way of identifing each one so i can get them in the right place! Many thanks!
Daviewonder
You could use a wiring diagram and a multimeter, only take a couple of minutes.
GSXR_J
Been scouring the haynes but cant tel head nor tale of it! Could do a continuity test from the joining plug but just need to know which wire at each injector corrosponds to what in the plug!
1.9 Mi16's fire all the injectors at once (batch fire) so it doesn't matter what order they're plugged in.
GSXR_J
Starman, many thanks indeed!!!!
GSXR_J
is this same for 2.0 mi16 too???
Mikey S
No, There sequential so they have to be plugged in in order.
Guest
