mikeyd
Lightened Flywheel
mikeyd
is there any advantage to having one on a rally 1600 8v or is it too revvy with not much torque ?
There's advantages and disadvantages, the same as any other mod really:
+ Improved throttle response and pick-up
+ Quicker acceleration, particularly in lower gears
- Makes the engine more sensitive to idle problems
- Easier to stall when pulling away if you're clumsy with the clutch
Given that a rally car will spend alot of time in lower gears and accelerating, and rarely idling or pulling away from a standstill, then yes, I would say it would be advantageous.
matt.f
I've got one and it's not a problem,a lot better
hcmini1989
Can i just hijack your thread here i was thinking about this on a 1900td but with out the extra weight would it mess about with the pump? I.e make it idle alot higher etc
