scottbarton
Coolant Level In A Phase 2 Expansion Tank
scottbarton
Hi all
Quick question.....
I have a phase 2 (H Reg) 1.9, and it has the black expansion tank. There is no level marking on this tank, as there are in every other car i have owned?
How do you know that the correct amount of coolant is in there?
I took the cap off and i can see coolant at the bottom, was just wondering if it should be more half way, or a bit further than that?
ORB
Top her up, it'll dump what it does not want.
scottbarton
OK. So you cant overfill then?
You can't strictly overfill it but ideally you want a small gap between the top of the fluid level & the neck of the expansion tank.
Once it's nearly filled & water is coming out of the thermostat housing bleed point, slowly fill up & keep checking the expansion tank level, shine a torch to help see the level if needed & if you fill to overflowing, waggle a finger inside to splash some out to make a gap or put some cloth in to soak some up.
Graham.
