1905 adam
Link Arm Boots - Anti Roll Bar
1905 adam
Hi,
1987 205 1.9 gti
The lower boot on one of my arb link arms is split. Is it possible to just replace the boot (part not listed in service box) or do I have to replace the whole arm?
Thanks in advance,
Adam
allye
The drop link boot? They are very cheap to replace, may as well replace both for about £20.
1905 adam
So you can just replace the boot? Not the whole arm?
allye
woops reading that back its confusing, I was trying to say you may as well replace booth drop links as they only cost £20ish for both. You prob could replace just the boot if you found one as they have circlip type rings on them, you would have to take it off so may as well replace it.
The boot is not available separetly to my knowledge. But the drop links are cheap enough to not worry and fit new.
1905 adam
Thank you gentlemen!
smithy
You can get boot on it's own I used one off eBay when I split my nearly newone.
eBay item number 280660791190
philfingers
that's me selling those on ebay, but they're for the bottom arm balljoint. I'm not sure they'd fit the ARB links. They may fit some but you get different sizes of boots on the ARB links depending on if they're genuine or pattern sometimes
Phil
