STEVEBOXER
Should Elec Window Switch Illuminate?
STEVEBOXER
Hi,on my H reg 1.9 pug should the elec window switches illiuminate when side/headlamps turned on???
cRaig
No, but as far as I know the switches out of a 405 (exectutive or something similar) should be illuminated and of the same style as the ones in the 205
Craig
Pugs in Pieces
most 405 switches are illuminated have fitted them to 205s on a few occasions now. dont think any 205 came with them......
STEVEBOXER
Hi,so a 405 elec switch is a straight swap is it?
The early ones will be a straight swap I think. The later ones seemed to be a slightly different fit from what I found at the scrap yard. I got mine out of a J reg 405 and they were exactly the same. The part that illuminates is simply a bulb in a yellow holder that actually could be removed and fitted straight into my 205 switch. New bulbs can be bought from Maplin for about £1.50 if need be.
monkee87
Have you got a comparison picture of both? I don't understand where a bulb goes on a 405 switch. Had a look in the scrappy today at 405 ones and they look identical.. :huh:
smithy
i have a couple of 405 switches the main body is the same as a 205 but the toggle part is smaller defo no illumination.
Take the "top" of the switch off the main bit - just unclips - you should see the yellow bulb holders inside, no doubt with blown bulbs.
