davey205
Cold Stalling
davey205
I have replaced;
SAD, tps - calibrated properly, checked and double checked all pipes for dirt or air leakage, cleaned idle screw and replaced usual service items - plugs. leads etc.
It still stalls when cold - the only way i can get around it is by upping idle to 1500rpm , once its warm the car behaves fine.
Is there something I've missed replacing or checking to cure this problem?
Edited by davey205
unariciflocos
Water temp sensor?
davey205
Yep, done that too, forgot to add.
kingboyk
Having the same problem (after an engine rebuild!). Did you sort it?
Edited by kingboyk
kingboyk
I'll start a thread of my own but if you have any info on how you cured it that would be great :)
Slo
its usually setting up the air screw but mine usually needs holding the throttle down for a good ten seconds before it actually idles properly also check the screw that holds the oil filler baffle to the inlet manifold its an interference fit which just in case you dont know means if its loose it will let air through the threads
