GTIJIM
[car_overhaul] Project Gti 1.9
laser_GTI
Mate doin a superb job!
I'm aiming to do the bumpers on mine when we have a few dry days. What paint did you use on the bumpers? Did you bother with primer though?
GTIJIM
after sanding i used Hycote plastic primer then a few coats of simoniz satin black :D
GTIJIM
got the new carpet in today :D
after taking allot of the interior out i had a little peek under the carpet :o
about an inch of water in the drivers footwell not a very clear picture though
so after grinding the nut off the passengers seat out comes the old smellt holy carpet
and the state of the floor :(
after a little scrub
water has been leaking in somewhere :(, so hovered the floor and sanded down the rust, then treated it will Hammerite Kurust
then painted over (only paint i had was anthracite :( )
GTIJIM
and new carpet in
and centre console
that's how i left it for tonight
peterjohnson6037
Doing a great job I'm enjoying following the story, it's come along way :)
Don't forget to find the leek or your new carpet will be wet also :(
GTIJIM
traced the leak to the door seals as they have perished so just got to replace them :)
GTIJIM
got the interior in today :) passengers seat took ages due to the frame being bent a bit :( but still got there in the end lol
gave it a wash :)
and interior
63,000 miles :D
Fox
Looks great! Keep up the good work!
damien
dont want to be nick picking but shouldnt the top hose from the expation bottle go to the top of the rad? yours looks like its resting on the engine. also your only using one of the PAS mounts, just bend the other one back to the slam pannel and jobs a goden.
your doing a great job on this, keep it up
GTIJIM
thanks :D
the one on the left of the expansion bottle goes to the top of the rad and the right one goes to the bottom of the throttle body but the previous owner has bypassed it to the top of the thermostat as the fixing on the bottom of the throttle body has snapped off, doesn't really matter as its only for cold starting so shouldn't affect the running:)
the tab for the slam panel has been severely bent out of shape so im going to have to try and get it to fit, looks like someone has stood on it and it got flattened lol :)
GTIJIM
well today was eventful, first i had to help my brother with his cambelt then when i went to my car for tools i saw that the passengers mat was wet, so i lifted it up and
oh dear :(
so after pouring a bucket of water over the car a substantial amount of water came from the sunroof so i peeled back the headlining and
its was missing the drain pipes from both sides :o so water was draining into the headlining and onto the carpet :(
so a bit of garden hose and a jubilee on both sides later
all fixed :D
GTIJIM
right got the exhaust welded up today :)
not the prettiest of welds but its really strong :), just need some exhaust assembly paste and a new conical gasket for the front and it should be a leak free exhaust :D
GTIJIM
Hi all
had the front off the car again today to try and fix the radiator:)
only had a tiny hole so filled it with milliput :D
all back together and no more leaks :D:thumb:
only a temporary fix so i can run the car without it over heating when im trying to set the timing / air,fuel mixtures:)
GTIJIM
just got a bit of cleaning done today :)
waiting for the service kit and some pipes to come tommorow :D
first off cleaned the passengers side door shut, was pretty nasty before
and after
and then onto the boot which i have been putting off for a long time lol
here's before
rubbers off
a bit of APC and a soft brush got me here
and hosed off
GTIJIM
Hi all :)
got my service kit today £48 :o thats spark plugs ht leads and an airlfilter plus
the downpipe gasket and some exhaust putty :)
here they are
heres the old gasket, took ages to get it off lol its been on there so long it was
nearly part of the manifold :lol:
and the nice shiney new one
fitted
and finnished fired it up and it was nice and quiet for a change :D
just got to get the few pipes i need and get it timed up and it should run like a beaut :D
GTIJIM
took a trip down the scrappy the other day and got me this pipe
its off an astra 16v but its perfect for what i need it for :)
so got the front end striped down (again lol)
and fitted
all back together but its still running rich and misfiring and wont idle :( but at least i know i have all the pipes now lol :D
got these form the market aswell :D all of them for just £6.50 :thumb:
and finally a picture of the back of it in the rain :D
GTIJIM
decided to take a bit of a break from the engine so got the front bumper done :D
here it is at the start
plate off
red strip off
lights out
grill off
and masked
then i put the first coat of satin black on
and finished
even did the horns :D
unmasked
GTIJIM
lights back on
grill and number plate on
then the all important red strip :D
looking much better in my opinion :)
then decided to try and get the engine sorted, finally got it running again(dodgy earth) and took a picture of the smoke (started clearing when i took the picture but it smells like pure fuel :( )
started mesing about with all of the screws and found out that the AFM had been messed with :( so did a little tweeking and the engine started to run better :) then it ran out of petrol:lol: typical lol
will get some more petrol tommorow and hopefully get it running proper :D
GTIJIM
set the timing today as it was slightly off and i really thought it would help it run better but sadly it hasn't :( i have a new theory now which is its either the AFM or something ignition related, but i tried unplugging the AFM and it didn't make it run any worse or any better so i think its gone :(
anyway here's a look under the rocker cover
and the smoke when running :(
Daviewonder
Are you sure thats smoke in the picture? It looks like Slimer from Ghostbusters.
dcc
I think I have an untouched AFM from a 309 gti, not sure if its the same as yours, but its yours for postage if you want it?
GTIJIM
lol definitely smoke :D
GTIJIM
Pm'd :D
GTIJIM
decided to strip and clean the throttle body today :)
pipes and AFM out of the way
bolts undone and throttle body off and look what was inside:doublesho
a mixture of petrol and dirt/oil :wall:
also this is the snapped bit but its only used for heating the throttle body on a cold day so its been bypassed :)
and cleaned
and in the plenum
and all back together :D
not tried starting it yet though i shouldn't imagine it would make much difference but at least now i know its clean :D
GTIJIM
and then decided to move on to the steering rack, its developed a serious problem which is if you turn the steering wheel the wheels don't turn :( and the rack makes a noise like cogs grinding :doublesho
so after some investigation its either the universal joint or its the rack itself which i don't really fancy changing as 1 its hard to get to and 2 its a power steering model which is very rare to find :(
so to investigate i decided to take the rack off so...
cowling off and some more dodgy wiring :(, going to strip the dash out and replace all the dodgy wires soon :)
steering wheel off and the 4 bolts that hold the rack on undone
just got to undo the two star bolts tommorow that hold the bottom of it on and it should just pull out :)
Edited by GTIJIM
