danny56712
Need Light Power Steering
danny56712
Hi guys entering car in few events here where i need very light powersteering. My 205 has power steering but too heavy any options besides major work like corsa cloumn
ORB
I am not sure if it will work, but you could try a smaller pulley on the Pump?? - not sure if they are regulated though...
monkee87
106/saxo Electric system would probably do you. :) Wheel and tyre size will affect the 'weight' of your steering.
matt.f
How much lighter is standard pas compared with manual steering?
True about wheel size,mine went lighter when I took the 15's off and put 14's on.
monkee87
Standard PAS is lighter than a manual rack. Most noticeable when parking etc, when driving normally it's not much different IMO.
I prefer PAS on my GTi. :)
Good idea but sadly not, as there is a relief valve in the pump which regulates the pressure. To make it lighter you would need to alter this relief valve to a higher pressure.
matt.f
Google' mk2mania' for corsa electric power steering conversions,tells you a bit on the website.Sells quite a few to people who rally.Just an option incase you can't find anything else.
SPGTi
Cheap option is to get a larger diameter steering wheel, narrower tyres and make sure your top mounts are in tip top condition.
Steve
omega
Steve
plus a couple of more psi in the tyres
tri_longer
In agreement with the 106/saxo electric pump conversion.
I'm running this, and my front track is considerably wider than standard and this still works nicely.
