vickiw106
Mbe 967
vickiw106
just managed to purchase a mbe 967 ecu.
i am going to run a 1.6 8 v engine running Honda throttle bodies.
i know the map on the ecu is for a 1.4 16 v vauxhall engine so therefore wont run my engine, does anyone how or where i can get a base map to start and run the engine before a remap?
i also have to build or obtain a wiring loose, does anyone have any suggestions on where to obtain good common sense wiring diagram, plugs etc.
thanks
Ian
Edited by vickiw106
SPGTi
SBD Motorsport are the main distributors and stockists for these. Have a look on their website. I know they can do pretty good maps for Vauxhall engines with just the spec you are running. A few 106's are rallying using this ecu.
Good luck
Steve
Sandy
Good luck indeed, make sure you get in touch with someone who can really, genuinely, do a good job with MBE, it's a tricky system to get right and few do.
