dave205
Mocal Oilcooler Sandwich Plate Stud
dave205
I have a 13row mocal oil cooler to run on my 205 turbo, but the adaptor/stud that the sandwhich plate sits on, wont wind into the block. The thread in the block is metric fine, and the other one is unf, any ideas on this??
Ryan
It means you've got the wrong adaptor.
They come in various metric and UNC/UNF threads to fit different engines. You need one with an M20x1.5 thread.
dave205
Do they come engine specific? As the the 406 had a water over oil cooler.
S@m
Just remove the old water/oil heat exhanger (cooler) and you are done.
Sam
Edited by Sam306
dave205
I have, but im fitting a proper mocal oil cooler, so need the correct lenght stud to fit the sandwhich plate.
S@m
The mocal stud length is the same regardless of whether you have the standard heat exchanger or not. I.E as long as its m20 thread (20x1.5) then it will be fine.
Sam
dave205
The original stud is twice the lenght of the mocal one.
large
If the original is twice the length can you not just cut it down?
dave205
Its not that simple unfortunatly, the original is male and male threaded and the mocal is a different thread, and its female and male, u 'll and get a picture on here
