Will Eastman
Fan Not Turning Off
Will Eastman
Whenever i turn my car off the engine cooling fan stays on for ages after making a right noise. Is this a problem n if so what can i do about it?
thanks
Obey_R
No the fans will stay on for a little bit if the engine is still hot. If you think about it, as soon as you turn your ignition off the engine doesn't instantly go cold! You fan switch will be set to turn off at something liker 78.C, whether the engine is on or off. Nothing to worry about though
smithy
As above nothing to worry about so long as it does turn off after a while and only stays on when hot.
The fan gets feed from a perm live in shunt box and not ignition feed that's why they do this.
Will Eastman
Thanks yeh it does turn off, just makes a right racket for a while. Chrz for putting my mind at rest though.
smithy
it will sound louder than normal as it is not being drowned out by engine noise.
