tomcolinjones
Fully Rose Jointed Wishbones From Compbrake
tomcolinjones
Just doing some research for my long term shopping list.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=320675898793&ssPageName=STRK:MEWAX:IT#ht_742wt_700
This is the price for the PAIR! and they are 200 on ebay, or 190 on there own website.
And what about the track rod ends they supply?
http://www.compbrake.co.uk/Parts-by-Car-Manufacturer/Peugeot/205/FORMULA-T/ROD-END-PUG-205-306-309/prod_3219.html
i was wondering if anyone runs any of these, and if so how long they last? there are no boots over the joints so mud / grit could get in easily and destroy the joint could it not?
Does the arm to hub joint last longer than conventional ball joints?
Thanks in advance..
Tom
Edited by tomcolinjones
Spiky
make your own, as the combrakes dont really fit and it's cheaper
tomcolinjones
Make my own wishbone? or make my own rose joints?
why dont the compbrake ones fit?
Spiky
as below make your own, these are a set i made, been fine :)
replacement RJ's are only 12 each too :)
the combrake one's fit if you retain the std ARB, even though they say they will :D
unariciflocos
Could you please provide some details on how you welded yours and where you bought the rose joints from?
Spiky
a professional welder welded mine,
i'm supprised my crew of "haters" havent been on and dissed them..lol
the inserts were made by another local welder/fabricator, they are the second set as the first were slopping with the rose joint
the rose joints were bought from
http://www.mcgillmotorsports.co.uk/
they sell lots on ebay, which is where i actually bought mine
unariciflocos
Did the welding process involve heating them in an oven?
And don't hate the haters, they're only thinking about your safety and that of others reading this thread and making poorly welded ones and having them fail.
I'm curious what Rippthrough's opinion on these would be...
Edited by unariciflocos
Spiky
no it didnt
tomcolinjones
I would rather buy something off someone who has a jig set up to make sure everything is spot on. wouldnt like the rose joints to be welded in on the p1ss or something, rendering the whole job usless!
The compbrake ones have adjustable arm to subframe joints aswell to adjust castor i guess?
I am just thinking of the not so distant future, and various routes to go with my suspension and steering. I can see the idea behind the rose joints to get the car setup 'spot on' and to keep it in tune when things bend / wear.
Would adjustable camber lower arms allow you to use 306 gti6 hubs? (readily available at the moment) and are lighter than the 1.9 items. so you could adjust the rose joint to give you negative camber, because the gti6 hubs give posative camber on a 205 iirc.
Spiky
Yeah that's cool, but the compbrake ones won't fit if you plan to keep the anti roll bar,
Trust me
TT205
^^ +1
Trust me too
tomcolinjones
^^ +1
Trust me too
Why do they make them then if you cant use an ARB? i beleve you, it just seems stupid!
TT205
Their old spiel was that they are mainly bought for forest use and the forest rally guys don't use an ARB
They insist (or did?) that they will fit with the ARB - the reality is yes if you get the car up on stands and unload the suspension - you can fit the ARB but when you drop it back on it's wheels - it catches
