SteveW
Gearbox Swap, Mi-16 Be1 To Be3
SteveW
I,m running an MI-16 be1 gearbox at present with lift up reverse and have the chance to by a be3 box with atb diff fitted. What mods are needed to fit the be3 or is it a straight swap, looking through some threads i think the mi box has the same clutch arm as a be3.
cheers
Steve
straight swap as such, fit the 205 selector arm and remove the lift up reverse cable and off you go.
unless its a Phase 2 Mi16 box where you'll need to fit the clutch arm+fork+bearing from the old box and remove the bracket for the mounting stud and screw the stud directly into the box.
Edited by welshpug
SteveW
Cheers m8, not to bad then
