Spiky
Can I Use The 205 Abs Hubs For Stack?
Spiky
thinking of ideas to run the speed sensor on the 205,
i know i can use hub bolts, or a magnet on drive shaft
but how about utilising the abs ring on 205 hub which had ABS?
I fitted an aftermarket electronic speedo to a 205 and just ran it off the sender in the GTI6 gearbox that people normally replace. I don't know what inputs the Stack clocks support but the Caerbont (Smiths) one that I fitted had no problems with the OE sender.
