Strictly_Derv
Rear Dampers
Strictly_Derv
Hi i've got some ebay adjustable coilies on my 205 and they came with rear shocks which i've put on. But it seems a lot softer at the back and you can feel it when going hard round a bend.
The beams on its way out sadly, after I lowered it the bearings where disturbed and its squeking like fook now.
What would be the cheapest way to stiffen up the rear? I'm a student working 2 days a week so expensive things are out the question :( and I won't be able to afford a beam for a few months yet
I've heard GTI6 shocks are good, is this true?
GTI6 rear dampers are a good upgrade from standard, not mega expensive new, and also commonly available 2nd hand.
What springs are on the coilovers - it's more likely you've just fitted stiffer springs to the front, and effectively not upgraded the rear spring rate (torsion bars) to match.
Strictly_Derv
no idea what the springs are, just really solid ebay jobbies, the backs standard Dturbo spec, anyone know the thickeness of the bars on these?
