Mad Professor
205 Gti Light Bulbs
Mad Professor
Good Day All.
Out of intrest I am trying to work out how meny light bulbs and what type are in a standard 205 GTi.
So far I have the following.
Desc, Qty, Watts, Amps, Fitment
Side Lights - Front, 2, 5, 0.83,
Side Lights - Rear, 4, 5, 1.67,
High Beam, 2, 60, 10.00, H4.
Low Beam, 2, 55, 9.17, H4.
Brake Lights, 2, 21, 3.50, P21W (BA15s).
Indicator Light - Front, 2, 21, 3.50, P21W (BA15s).
Indicator Light - Sides, 2,
Indicator Light - Rear, 2, 21, 3.50, P21W (BA15s).
Reverse Light, 1, 21, 1.75, P21W (BA15s).
Rear Fog Light, 1, 21, 1.75, P21W (BA15s).
Number Plate Light, 2, 5, 0.83,
Interior Light, 1, 5, 0.42,
Glove Box Light, 1,
Boot Light, 1,
Clock Light, 1, 1.2, 0.10,
Cigarette Lighter Light, 1, 1.2, 0.10,
Heater Dial Lights,
Dashboard
Oil Pressure Warning Light, 1, 1.2, 0.10,
Low Fuel Warning Light, 1, 1.2, 0.10,
Brake Pad Low Warning Light, 1, 1.2, 0.10,
Glowplug Heating Light, 1, 1.2, 0.10,
Left Indicator, 1, 1.2, 0.10,
Stop Light, 1, 1.2, 0.10,
Hand Brake Light, 1, 1.2, 0.10,
Battery Light, 1, 1.2, 0.10,
Low Water Level Light, 1, 1.2, 0.10,
Side Light, 1, 1.2, 0.10,
Low Beam, 1, 1.2, 0.10,
High Beam, 1, 1.2, 0.10,
Choke, 1, 1.2, 0.10,
Right Indicator, 1, 1.2, 0.10,
Engine Man Light (K-Light), 1, 1.2, 0.10,
ABS, 1, 1.2, 0.10,
Oil Temp Warning Light, 1, 1.2, 0.10,
Water Temp Warning Light, 1, 1.2, 0.10,
Back Lights, 6, 1.2, 0.60,
I can't think of anymore right now, but I am sure someone will point out some I have missed.
Best Regards.
Edited by Mad Professor
Henry Yorke
Side Lights - Front, 2, 5, 0.83, 501
Indicator Light - Sides, 2, 501
Glove Box Light, 1,
Boot Light, 1,
Heater Dial Lights,
Dashboard
ABS, 1, 1.2, 0.10,
I think all the dashboard ones are "T10" but not 100% sure. All the bulbs in the clocks are the same and match the heater dial and clock bulb. And you are missing the GTI front driving lamps which are H1 (but check that I am right!)
smithy
Think the driving lamps are H3
ORB
Map reading light as on GTI models...
Pugleyrich
Sorry to revive an old thread but can anyone confirm the bulbs for driving lights are H3? Thanks
Pugleyrich
After a bit more searching I found it, H3 55watt
