large
Mot Time No Abs
large
Brakes Breaks work fine apart from no abs, Will it pass?
Edited by pug_ham
If ABS is fitted it needs to work, i.e. the light comes on with the ignition then goes out again.
monkee87
It's usually the connections on the top of the ABS pump. Clean them up and see if it's any better.
Also, don't know if you know, but you have to turn the ignition on, let the light go out and then start the engine. That's if it's a crappy 205 ABS system! ;)
