large 33 Posted March 21, 2011 (edited) Brakes Breaks work fine apart from no abs, Will it pass? Edited March 21, 2011 by pug_ham Share this post Link to post Share on other sites
jackherer 543 Posted March 21, 2011 If ABS is fitted it needs to work, i.e. the light comes on with the ignition then goes out again. Share this post Link to post Share on other sites
monkee87 2 Posted March 21, 2011 It's usually the connections on the top of the ABS pump. Clean them up and see if it's any better. Also, don't know if you know, but you have to turn the ignition on, let the light go out and then start the engine. That's if it's a crappy 205 ABS system! Share this post Link to post Share on other sites
