choochoo
Rear Brake Caliper Question
choochoo
My rear caliper on my car has give up. when i press the brake it works and dont retract and its binding all the time and eat a set of pads in a week. I was going to get a new one but my mate has some off a saxo and it looks simular , Any idea if it will fit??
Saxo ones are the same. Make sure it isn't a perished and collapsed brakeline causing the brake to bind though
choochoo
Ive checked the pipes and look fine, ive had the caliper off twice to put new pads in and i have to undo the bleed nipple to wind the caliper back in. some things not right with it some where .
Thanks for your reply
j_turnell
Could it not be a compensator problem? May be worth throwing on the saxo caliper and go from there.
choochoo
Yer i will do and see what happens . hopefully it is the caliper and not some thing else
next time you try and wind the piston back in, crack off the union on the calliper side of the brake compensator.
choochoo
Do you mean undo the pipe
