stu8v
Cost Effective Trackday Rear End
stu8v
Right I'm trying to do a little forward planning in respect of the rear end, mainly so I can keep a lookout for parts as and when they come up.
What is the most cost effective way for me to build a tarmac/trackday spec rear end. In respect of Anti Roll bars, Torsion bars, Dampers etc etc
So far I've collected a pair of ZX rear arms, a std 1.9 beam and a std 1.6 beam to use for spares as /if reqd
From the searchs I've done it seems to be a case of 21mm torsion bars, 25mm A/R bar and Billies, is this still the preffered option.
Tbh any thicker TB's are worth while if you can find them but most commonly used sizes in the aftermarket was 20 & 21mm afaik (SBC etc).
Same goes for the rear arb but its more a matter of what sizes you find available, I expect 24mm to be more common using resplined 306 arb's than proper custom made 25 (or bigger) ones.
Graham.
oli-pug
Depends how you want the car to feel on the track and what tyres you're planning to use. It's no more expensive really to go for a stiff setup with very little roll over a softer more compliant setup.
madaxgt
Where do you get ARB's resplined?? I would be interested in where you can get splines re cut
j_turnell
Just use a 106 gti 24mm rear arb with 306 end plates, bolts straight in.
