JRL
Upgrading Or Downgrading
JRL
A few mods I have taken from the 205 XS/rallye: Rear quarter windows these are the non- opening type and so far have not leaked as apparently the seals are less prone to shrinking probably due to the fact that the glass goes inside the seal and helps hold its shape.
XS\Rallye rear interior cards, I have always prefered this style they dont creak like the gti cards and they continue the red stripe on them like the fronts.
What else have you used from the non gti models?
JRL
Mods: I cant get images to show, what am I doing wrong? if its possible please rectify.
thanks
You'd put http://http:// in the image path - removing one of the http:// fixed it.
The images are a little on the large side though and a bit smaller is prefered if at all possible
Another thing that you might like and which would go well with the semi-stripped yet comfortable ethos of your car is the base model gear lever surround and lower heater vent setup, which replaces the sizeable lower center console and gear lever surround on GTi's and other higher spec 205's. A picture courtesy of Jonny Goodhand...
Downside however is that you lose the storage space that the GTi lower console has
JRL
Brilliiant thanks Anthony! I have been putting my photos on photbucket and it downsizes them il work out how to make them smaller.
As for the centre console that is very neat.
Daviewonder
I like the coloured seatbelts and carpet that came in many of the lesser models, a nice way of colour coding the inside of your GTI.
