rallyeash
[trackday_prep] 205 2.1 16V Rallye Track Car
rallyeash
oh thanks!
well on the other hand the return pipe is higher than the pump so in theory it will kind of gravity feed itself when the tank is full?
does a Bosch pump suck the fuel aswell as blowing it (for want of a better word) I've never tested it.
rallyeash
next up was to sort the exchaust tunnel out..
originally i picked up an 4-2-1 Maniflow 306 4 branch manifold for £30 rather than spending £500+ on a new one. Only 2 problems with it was it had cracks around all the welds and it was for a 306. I gave it to my old man and the next evening it was all welded back up which just left the problem of it fitting a 306 not a 205. This meant i had to cut the old exhaust tunnel out and knock up a new one... that was 2 years ago now and ever since then the tunnel that i knocked up for it has been annoying me.
i havent got any proper pics but you can just about make it out in the corner of this pic..
So Saturday i chopped it all out and got 1M of 1.2mm sheet steel to make a new tunnel, then when funds allow i can purchase another Satchshift which should now fit where as it wouldnt with the old tunnel.
its still got along way to go but this is the shape all tacked up and fitted, to get the curve and for it to sit fairly close to the manifold i had to make it in sections. Another evening will see it all ground back smooth so it looks much better then weld it all up, clean and some fresh paint.
Spiky
Nice one :)
rallyeash
dry sump stuff all turned up this morning from Kam Racing..
test fitted it all onto the sump in my office at work, Boss seemed chuffed!
eagle eyes will see the satchshift sitting on the desk which im fitting this evening as car is currently at work.
Ive also just re insured it and MOT is booked for saturday morning. Fingers crossed, although moving it this morning it seems to only be running on three cylinders?!
Sandy
Fresh set of plugs. The type I've fitted, not the listed ones!
rallyeash
cleaned them up and perfect again..
just finished fitting my satchshift but it fouls on the exhaust manifold as ive got a maniflow one... more work to be done tomorrow!
rallyeash
Satchshift all sorted, feels ace when giving it some, gears are so close together.
MOT passes yest and 6 months tax purchased so it's all legal once again :-)
rallyeash
pictures!
front bumper off
old alternator setup
sump off
new sump fitted and crank pulley drive fitted
pump test fitted
alternator now bolts up under here, need to sort an adjuster still
next thing was to think about the location of the tank, i didnt want to put it in the boot because pipework is a pain in the ass so its going to fit infront of the gearbox in a cradle nr the nearside head lamp.
purchased new 19mm oil hose to replace the scavenger oil pipework on the sump
purchased some sheet metal to make it
updates this evening with tank location and fabrication!
rallyeash
this is where the tank is going to sit...
so a cradle to hold it was knocked up, tacked in place currently but will weld it all soon.
tank sits in like so, need to sort a strap to stop it falling out now.
Spiky
just rememebered, the fuel pump running ok now that its not being gravity fed?
rallyeash
Yeah no issues. Nearly ran out of fuel at Combe last time and still fine
Spiky
great news :)
sambaileyw
Hi Ash,
Silent admirer cars absolutely awesome btw.. and the cage :o
Have a question about your suspension setup, your running 23mm torsion bars what rear arb and front arb are you running and what front springs have you got?
Shakey_Jake
Dry sump is a proper bit of kit!
Have you had issues with low oil pressure on track before?
rallyeash
Thanks for the comments.
Yep I'm running 23mm tbs, 24mm rear arb and standard front gti arb. I think 300 springs but I can't really remember!
Yeah it is a proper piece if kit! No I haven't but I'm looking at more grip next so I think it was on the edge anyhow....
rallyeash
making brackets...
all plumbed up now, turned the pump by hand to get the oil up around the system, then whipped the plugs out and cranked it over. got 2 bar on the gauge so everythings working as it should. when the engine is started pressure will rise up alot more and i might need to adjust it on the pump but before all that i need to get the coolant plumbed back in...
Shakey_Jake
Yeah, better safe than sorry with that engine!
chipstick
Looking good Ash :)
I notice you've bolted the oil cooler directly to the bracket without any rubber buffers. I understood the coolers are quite sensitive to vibration?
Spiky
mines effectivly the same (behind fog lamp holes)
never had an issue :)
chipstick
I'm intending to pop mine behind a rallye blank. Hopefully there's sufficient room. Got any pics of yours squeezed in behind there Steve?
Spiky
here you go
supercharger cooler on left,
oil cooler on right
rallyeash
My old wet sump setup the cooler was bolted directly and that has been fine for 2 years and 20+ trackdays so I'm sure it'll be ok.
I could rubber mount it as there's room to but I don't really see the need on mine
rallyeash
its alive once again!!
oil pressure is holding a strong 4 bar from cold to 10 minutes running time.
click the pic for a video!
before anyone says anything the breathers are bodged blocked up so i could run it up
Edited by rallyeash
rallyeash
got the alternator side of things sorted last night.
where it bolts into the tab sticking out the block an M8 bolt is required to screw into the thread available on the block, although the alternator hole is for an M10 bolt so abit sloppy and not ideal.
so i found a bush at work with an 8mm internal and 12mm external so i drilled the alternator out and fitted the bush which made it all sit nice and tight so the alternator got bolted back up again. Next was to sort an adjuster/second support so after a little bit of thinking i made this...
not an engineering work of art but looks smart enough and does the job it needs too.
all thats left now is the coolant system and blank off the breather outlets cause the dry sump is a sealed system.
Spiky
smart :)
doing the RSOC day at combe?
