dcc
Help Choosing A Setup
dcc
Basically as in the title, I am trying to do soem research into the best value for money nd money for performance on the items listed.
Ideally want to keep everything I need below £2000, or there abouts!
I have thoughts about buying a complete new package from Emerald, but it wouldnt include an inlet, mapping or suspension! :(
oli-pug
What engine are the throttle bodies going on?
What suspension setup is on the car at the moment?
dcc
its a standard 1.6 gti as we speak, with 309 front wishbones.
the car will likely be going for gti6 treatment soon
oli-pug
hmm tough call then, all depends what you're using the car for... but i think you find a better performance benefit fitting a limited slip diff before going for more power, then make sure the beam's all sound as this can get expensive.
dcc
beam is fine on the back, will be tripped and greased when its moved to its home for a few weeks
Got your message, i'll get bac to you asap!
Batfink
get a diff, then get bodies for the GTi-6 engine.
