Jrod
4mm Hose Blank
sonofsam
Do those get clamped on the inside or outside of the hose?
around the outside I'd imagine, 4mm i.d.
I think there are some used by Peugeot/Citroen on some of their XU10 turbo manifolds, possibly some on the throttle bodies too, will see if I can find any....
naah, plastic and have a hole in the end ;) go through lots at work!
sods law, Servicebox says NFP :D
0311 17
NFP
PLUG - TURBO INJECTION XU10J2TE
not sure what size this one is specifically though.
remembered about one I saw on a V6 though :)
1624 60
PLUG 4,3X9,3-20 - INJECTION ES9J4
£1.31 :D
found some 14.5 and 20.5mm ones too.
Edited by welshpug
Jrod
naah, plastic and have a hole in the end <_< go through lots at work!
remembered about one I saw on a V6 though :D
1624 60
£1.31 :D
Someones got too much time on their hands! :P
Any idea if they are fitted to the ES9J4S aswell? If so I could compare them with mine to see if they will do the job. :)
Edited by Jrod
too much time? once upon a time <_< took a few minutes at most to find that :)
doesn't look like there are any similar takeoffs on the ES9J4S.
I just cross referenced that part number on servciebox, it is the same one found on the underneath of an 8v 205 gti's throttle body :P
as well as quite a few carbs.
shalmaneser
What are you trying to blank off?
I managed to blank off the carbon emissions hole on the throttle body with one of the screws from the coil pack cover, it's exactly the right size and looks very neat.
On;y reason I say that is those blanks look about the right size and I can't think of much else you need to blank off....
Jrod
As pictured, the hose works fine... Just like something that looks a bit less of a bodge. ;)
