Andy F 0 Posted February 16, 2011 Hi everyone I am currently routing my brake lines. I have fully braided hoses made up by Earls motorsport. I have the fronts clipped is basically the same place as the original rubber/copper combo would be. I am currently trying to route the rear. I was debating going through the boot floor straight to the calipers. As its a track car only a spare wheel will be fitted in the boot. I wondered if anyone knows what the mot actually requires. Do they just have to be secure and able to move with the wheels? Thanks Share this post Link to post Share on other sites
welshpug 1,645 Posted February 16, 2011 I dont think going from the boot floor to the brake caliper directly will work due to the proximity of the chassis rail to the caliper on full compression, as well as how far the wheel moves on full extension. You'd need to follow the trailing arm as the original lines do which is easy enough. T piece in the rear seat well, then out to two bulkhead fittings above each damper lower bolt them around and down the trailing arm, easiest way IMO is to use solid line down the arms all the way from the bracket on the lower damper bolt to the caliper as the 306+xsara came from the factory. Share this post Link to post Share on other sites
pug_ham 243 3 Cars Posted February 16, 2011 If you're following the original lines I wouldn't use braided hoses at the caliper end just solid copper lines straight into the caliper ala 306's etc like Mei mentions above. This is how I have my 205 piped in & its fine plus there is one less flexi to fail & two less joins in the system to rust up. Graham. Share this post Link to post Share on other sites
shalmaneser 26 Posted February 17, 2011 If you're following the original lines I wouldn't use braided hoses at the caliper end just solid copper lines straight into the caliper ala 306's etc like Mei mentions above. This is how I have my 205 piped in & its fine plus there is one less flexi to fail & two less joins in the system to rust up. Graham. This. Makes much more sense, it's how ive done mine. Share this post Link to post Share on other sites
