Petrolsniffer
Rust Around Windows
Petrolsniffer
Hello all fellow 205er's
Just wondering if anyone has any idea how much it'd cost to put these patches of rust right?
As I know if I leave it it'll cause me more grief in the future I don't really want water seeping into the dash causing electrical havoc!
If you lift the rubber on the window you can see it goes deeper
omega
dont now about cost but for the windscreen one i would take the screen out and have a good look ,why not do it yourself? but would do it sooner rather than later.
Petrolsniffer
If I had a garage i'd would try myself
Wouldn't like leaving it in the open without the screen and I have no idea how to remove it safely
omega
removeing it is easy peel the rubber down from the inside and push out to replace you need some strong string to but inside the rubber to pull it back in,you would be able to do the job in a day.you will need some primer,etch primer,paint,sandpaper,kurust.sand/grind the rust back to bear metal,treat with kurust,wash off,prime,etch primer,then paint.
