4ll5op
Original Head Unit
4ll5op
i have recently installed an original 205 gti stereo but think i need the security code doing as the stereo wont respond but i can hear a radio station is this normal? nothing works except volume,bass,treble,fade and balance but with the volume up all the way i cant hear the stereo once i start my car is this because i have powerful speakers and not the original ones
please help
thank you
boldy205
I wouldnt think it was because you need a code, as without the code you most likely wouldnt get any sound.
Try swapping the head unit for a known good one.
I doubt its because you have uprated speakers.
Matt
4ll5op
cheers for the reply mate i sorted it this mornin on the way to work i had some instructions for the stereo when i bought the car so i dug those out and it says to hold down the band button to clear wrong security code attempt then try again so to make sure it had cleared i pressed 1 four times and to my delight that was the security code although not very secure.
another thing if i wire up a head unit in the glovebox is there a way i can just have the lights come on on my original head unit?
Obey_R
You can just splice into the power, earth and ignition leads from the new headunit. It will then come on and off with the ignition, you can set it to certain stations (for the display) but there won't be any sound.
It's really just a case of splicing into the right wires.
4ll5op
Ok cheers the sound will be coming out of the stereo in the glovebox anyway mate i just wanted the original headunit to light up like an xmas tree are there any disadvantages of having 2 headunits wired up eg using too much power?
