RGT100
Help Arb Stuck
RGT100
HI
I have a 306 disc axle and am trying to remove the ARB i have removed the end cap from the one side and striped the thread in the other
my problem is i have removed driver side end plate but the shaft is solid i have bashed the s*ite out of it but it hasn't move at all am i missing somthing here from the guides it looks as if it just pull out?
Edited by RGT100
j_turnell
Can you not put the end plate you removed back on and push it out the other end, just use a rear caliper bolt or alike and copper grease before winding it in.
RGT100
hi
its siezed on the other end and i have stripped the thread so i can not get it off
is it a case of keep hitting the ARb i only ask as i am starting to mangle the end of it
j_turnell
So you have removed one end plate correct?? Are the threds fine in that? If so remove the bolt, put the end plate back on, undo the 13mm on the other end plate and wind the bolt back in to push it out.
RGT100
I have stripped the threads in the other end cap while trying to get it off
j_turnell
Right im with you now, in which case, gently prise it off with a pry bar to try and break the seal a little and then smack the other end with a copper hammer or alike as not to damage the end of the arb. If you can get the bolt to go in atall, wind it in a few threds then tap the bolt up and down to help break the seal on the arb.
RGT100
Also with the 13mm undone the end plate wont turn at i tried to move it around to free it
RGT100
I'l give it a go
So is it the end plate thats seized not the ARB?
Also im going to need another endplate as there are no splines left in the one i took off can i get one of any 306 or are the splines different for the different thickness ARB's
RGT100
finally got the end plate off bent like hell but off
BUT the ARB is still solid in place is it just rusted in
How do i go about getting it out now is a normal occurance or am i just unlucky
Also the ARB dosn't sit smack in the middle of the trailing arm its slightly to the side
jord294
it sounds like your bearings have collapsed and the axle was suffering camber issues before you started stripping :)
from experience o/e trailing arm shafts only had approx 30mm i/d, and the arb is 24mm
so if you did have camber, it is quite possible that the old bearing, grease, dirt etc has got into the tube and solidified
with the off centre angle of the arb going through the smaller end of the trailing arm shaft, this is why your having trouble removing it
hope you can understand that ^^^^^^
RGT100
So how do i go about getting it out
jord294
if what i said is correct, i wouldn't even of entertained stripping it in the first place.
only way to do it really, is to take the complete trailing arm, torsion bar, and arb out at the same time
BUT that could be a task in itself
portapower FTW :)
RGT100
so im really best off taking it back to the breakers and getting another
What i am trying to do is get a reasonable axle rebuild it and then replace the one on my hdi but if it is as bad as you say best of taking it back
But as i have taking bits apart are they likley to take it back now i have part taken it apart
jord294
very much doubt they'd take it back
i take it this was gonna be your first beam rebuild?
if it helps, i can supply you rebuilt beam?
RGT100
I wouldn't be able to afford it buddy i know how much they go for
That reason why i was going to rebuild it over a couple of months
I ll see if i can get it swaped in not ill take the trailing arms and Arb dont want to take any more apart intill i can see if i can get it swaped
is there any thing that will else that will cause the arb to be on the piss
Also i made some meaurements
hub to hub
Top to top 1450mm
Bottom to bottom 1460mm
Whats the standard camber on the 306 as thats a 10mm camber inwards at the top on just the hub would be moore if the measurement was on the wheel
RGT100
How come with all that camber the suspension still moves up and down freely with my weight on i would of thought it would of been solid
It was solid when the ARB was connected but now ir bounces up and down nicely
of you have the end plate off one side, the ARB will just pull out of the other side, undo the 13mm bolt.
may need to tap the end of the ARB to break the seal as the small yellow one tends to stick quite well.
RGT100
Right i have took the Axle back and they gave me an exchange unit the only difference is the beam is black instead yellow is there any difference
Yellow one came of a HDI-Dturbo
Black one came of a hdi
Are they different or is it just painted to look better on the D turbo
The one on my car is black anyway i have 20mm Torsion bars and 20mm ARB i didn't measure the yellow one
jord294
tbh, i relly don't think the colour matters for the crosstube
i'm baffled now as to your plans for the beam
is it to upgrade the beam on your car (what car is it by the way?)
or just to replace a tired beam?
i know the 306 xsi/gti uses 20mm torsion bars and a 24mm arb
iirc the 306 hdi estate uses 21mm torsion bars (same as xsara vts) but not sure on arb size
DTurbo hdi is the same spec as xsi and gti6/rallye being a sport spec beam, if its from a straight HDI it's likely to have something like 19mm or 18.9mm torsion bars and a thinner ARB.
RGT100
My axle is very tired and need replaceing squeeking Etc 185,000 on clock
so i got a replacement axle to rebuild and lets face all the 306 axle now could do with new trailing arm bearings
also as im taking it all apart if i come across a Gti Xsi in the breakers ill take the Torsion and AR Bars
With the case of torsion bar thickness is thicker the better
Ie Would 306 Estate 21mm Torsion bars be better than 20mm Gti even thought the GTi is better handling
I assume ARb is thicker the better from the seach i did
for future info are Front Hdi Lx springs the same as HDI Dturbo front springs or are the gti springs
Example If i put Gti/xsi/Estate torsion bars in would it be best to fit GTi/Dturbo Springs
jord294
i think the noticeable difference will be the 24mm arb from the xsi/gti
but from experience, the 21mm torsion bars do make a difference
it all depends on what you want to do with your car
RGT100
My replacement beam has 20mm Torsion bars and a 20mm ARB so if i fitted a 24mm ARB essentially it would be a GTi Rear beam?
jord294
yes :lol:
RGT100
I would like smooth ride with good handling but i know i would have to sarifice ride for handling
I assume the ARB dosn't affect th comfort
I don't want rock hard suspension How much harder would the suspension be with 21mm Torsion bars or is it minimal for the amount of improved handling?
The car Will remain at standard Height
The reason i ask is there is a hdi estate in the breakers near me and he quite cheap as you have to remove the parts your self
Edited by RGT100
