gaz832
Fuel Pump Connection ?
gaz832
just wondered about the white connector that plugs into the fuel pump, i have just got a spare one and wondered if i just cut the wire and put new crimped connections on will it still work as normal. as the pump i got i off another year of car ?
CTI STU
Yes it will, Well I done it on my old Gti and it worked fine :lol:
gaz832
hi folks, just to say the car is on the road again, had a problem withthe ignition wiring to the fuel pump. so i ran a wire straight from the battery to a kill switch then wired to the pump. starts first time now. it has also added a bit more protection against theives i think. have the switch hidden where only me and my mates no where it is. woo hoo happy days. god ive missed driving it.
Edited by gaz832
GLPoomobile
Drivers side rear ashtray :lol:
smithy
hope it is fused if taken direct from battery?
gaz832
thats 1 of many jobs on the car today . just wired it as i needed it running . still having fuel problems under full acceleration the car is holding back, any of u guys had that , its mainly in 3rd,4th and 5th . might be my fuel pressure regulator. ?
smithy
i think i have read somewhere that some of the fuel pumps can cause that problem for some reason,think p1 pumps but not 100% sure.
also i had a 405 sri on a Hplate some years back that would do that unless tank was over half full,under acceleration it just bogged down,turned out to be a tank breather issue.
