cheesegrater
Removing C Pillar Trim?
cheesegrater
How do you get the c pillar trim off? I'm trying to get new speakers in.
Tom
monkee87
You can prize the speaker grills off and you should be able to squeeze the new speaker in. It's a tight fit though..
CaptainK
^^ this it what I did when I replace my rear speakers. It should be noted there wasn't a lot of slack in the cables to the speakers, so it'll be fiddly wiring up the existing short cables to the speaker, or extending the wiring slightly.
smithy
Tom
I removed mine to fit new speakers but it can be done just about in situ.
if you want to remove there are a couple of screws in panel and also one throught the spring loaded parcel shelf holder and then 2 through the bracket for rear seat back rest.
it is then held on with clips so will need a bit of a pull to remove.
