Daviewonder
Rear Beam Front Bushes?
Daviewonder
Hello All
I'm just on Service Box making a list of the bits I need for my rear beam rebuild. I've got to the "flexible joint bushes" for the front of the rear beam (top hat ones), there is 2 types listed, one with a white paint mark and one without. Does anyone know what the difference is apart from the white paint mark and the fact one's twice the price of the other?
Cheers :lol:
one type is stiffer than the other.
5131 74
02
FLEXIBLE JOINT
- GT AND GTI
is what you need :lol:
Edited by welshpug
jord294
pretty sure the one version is for non gti, as the others are same number for 309s
5131.74 is the ones i always use when building beams :lol:
miamichris
Not sure about which one of those you would need, but I can recommend giving Stew at baker BM a shout and getting a set of his acetal bushes as you can buy them seperately from him :lol:
http://www.bakerbm.com/205.php?data=suskit205a
Daviewonder
Thanks for the fast replies. So the ones I need are the cheaper ones, that makes a pleasant change. Are they priced each or per pair?
Chris - I've already bought some GrpN mounts so I'm just after the front standard ones now.
Cheers :lol:
Edited by Daviewonder
Ryan
They're priced each, so you need four of them.
dino20vt
5131.74 is the ones i always use when building beams :D
Do you build beams then? I never would have guessed :lol:
jord294
Do you build beams then? I never would have guessed :D
it has been known :lol:
