vern
Camshaft Oil Spray Bars
vern
Are the camshaft oil spray bars supposed to be a tight fit into the mounting holes?, as mine is quite easy to pull off, and I am worried it will come off as soon as the oil gets upto pressure.
jord294
they have little o rings fitted, which can be bought seperately
iirc the manifold itself costs about £30 new
smithy
mine was easily pulled off when i stripped head down,fitted some new o rings when rebuilding and it is a nice tight fit now.
vern
Thanks for replies, service box only lists the bar complete and is not available. Smithy did you just use standard round O rings as they appear to be square ones.
smithy
yes i have got a couple of box's of assorted o rings from work just put the ones that best fitted on,been a few months since did it but if i remember correctly the plastic journals are square but part that slots in to the cam caps was round so standard o ring fitted fine?
jord294
you'll find the o rings listed under the mi16 (xu9j4) engine :lol:
vern
For any searchers part no is 1166 21 and can be found under the 405 as mentioned by Jord, they are about £1.20 each. I will have a go with O rings first. Thanks for all replies.
They can't lift out, even with old o-rings, as the cam cover has bosses which hold them down.
C_W
I didn't know that. But if they come off easily with the rocker off then it's usually because the o-ring has shrunk/hardended so new ones should give it a bit of grip.
