GLPoomobile
Whistling Sunroof. Leaking Seal?
GLPoomobile
2nd attempt to post this (s*ite internet B) ), so I'll be brief.
Sunroof (standard fit) whistles at motorway speed. Problem has got worse (used to only be at very high speed). Think it's loose trim as get an occassional rattle.
Gonna be taking entire sunroof off soon for mass cleanup, and want to rectify this fault while I'm at it.
Has anyone had this problem and found it was caused by something else, for example the seal being worn or not inflating fully etc? How did you fix it?
mogsman
My sunroof also whisles but the corner of the trim on the drivers side lifts up. My seal seams to be working properly and inflates well. If I could be bothered to fix the trim I would know for sure.
Ian
does your windscreen have the sunroof type seal with a taller lip at the top or the non sunroof type that's the same profile all the way round?
GLPoomobile
Correct sunroof windscreen seal. Sunroof all works as it should and seals watertight (except the usual leaking handle washers). I'm hoping that everything is fine with the seal and it's just a loose bit of trim (allowing the glass to lift slightly at high speed and break the seal). But would like to arm myself for when I actually have it all apart, which is why I'm keen to hear from anyone else whose actually had and fixed the same problem.
