Iain-gti 6 Posted January 12, 2011 Hi, There is rust along the bottom edge of the windscreen, not sure how to fix it. Anyone got any ideas?? Thanks Iain Share this post Link to post Share on other sites
welshpug 1,646 Posted January 12, 2011 (edited) remove the screen and treat the rust however suitable, be it rub down prime and paint, or cut out rot and weld in new steel. Edited January 12, 2011 by welshpug Share this post Link to post Share on other sites
Iain-gti 6 Posted January 12, 2011 Thought you may say remove windscreen. Trying not to remove windscreen as its a pain to refit. I hoping there would be a in genius plan. Share this post Link to post Share on other sites
welshpug 1,646 Posted January 12, 2011 yeah, get someone else to remove the screen, its not difficult on the 205 as it is not bonded. Share this post Link to post Share on other sites
Iain-gti 6 Posted January 12, 2011 Like who?? company? Share this post Link to post Share on other sites
omega 82 Posted January 12, 2011 do it yourself its easy. Share this post Link to post Share on other sites
Stevo309 0 Posted January 12, 2011 Hit it with a hammer, fix the rust then call your insurance company and get them to come and install a new one Share this post Link to post Share on other sites
Iain-gti 6 Posted January 12, 2011 I can remove it, doing it Rambo style . But refitting is the tricky bit. Share this post Link to post Share on other sites
mickie 3 Posted January 13, 2011 its harder to remove than refit.. honestly its soo easy to fit a 205 windscreen Share this post Link to post Share on other sites
pugpete1108 62 1 Cars Posted January 13, 2011 agreed, its far easier to refit than remove. i shmashed mine trying to remove it. good job it was cracked already hence why it was being removed Share this post Link to post Share on other sites
Jrod 7 Posted January 13, 2011 Fold the rubber back and jam 2ps in between the seal and the actual frame, do this all the way along the top until you can get a corner out then it just slides out. Easy! Share this post Link to post Share on other sites
SurGie 54 Posted January 13, 2011 Fold the rubber back and jam 2ps in between the seal and the actual frame, do this all the way along the top until you can get a corner out then it just slides out. Easy! Do you mean put the 2p's from inside the car ? Share this post Link to post Share on other sites
Jrod 7 Posted January 13, 2011 (edited) Yes, If you try it and have a bit of common sense you'll figure out exactly what I mean. Edited January 13, 2011 by Jrod Share this post Link to post Share on other sites
harryskid 193 Posted January 13, 2011 If your well off, try 50ps Share this post Link to post Share on other sites
MerlinGTI 3 Posted January 15, 2011 Yes, If you try it and have a bit of common sense you'll figure out exactly what I mean. If your well off, try 50ps I love this forum the 2p idea is mint too Share this post Link to post Share on other sites
