gaz832
Interior Switches.
gaz832
just wondered about the 3 switches in the car hazard , rear window and front driving lights. are these standard fit in all pugs as my switches are getting quite worn. can i just change the end caps or the whole item itself. seen some 206 and 106 cars in the scrappys with the same .
Edited by gaz832
allye
standard across all 205's (ph 1.5+), and as you said 106's, 206's and 306's (parts bin special!)
take the fascia panel off and they just pull out and unplug and replace. <_<
gaz832
cheers mate scrappy hunt the mnora, will i just pocket them lol.
allye
Haha <_<
Thats what I do with small things
johnnyboy666
*rear fog light is it not?
MerlinGTI
106 hazard switch fronts are red. This makes the 'suddern stop on the motorway hazard light switch hunt' far more efficent I find <_<
The front bits do seperate from the rest of the switch. Pug cant supply the correct bulbs either (they have really long tails, pug kept sending me short tail ones untill I gave up), so make sure you get some that work.
