Paul Smith
Water Washer Jets
Paul Smith
Hi
Has anyone had this issue, you have to pump the stalk to get the jet to spray water? Once it starts spraying you can hold it and it seems fine but as you as you stop you have to pump the stalk again.
I thought it maybe the 12v motor playing up so got a new one swapped it and exactly the same?
any thoughts?
Paul
GLPoomobile
Worn contacts in the stalk?
happygoron
Or worn contacts to pump, mine had that.
Paul Smith
I'll try the stalk first can they be cleaned or is it a replacement
Daxed
Same symptoms on mine, swapped the stalk, problem gone.
