stuart1298
Wiring On Xu10jte Powered 205
stuart1298
right, fianly went to start her today,
i bought a ready made loom and ecu, which was from a running 205 turbo
my problems
no power to fuel pump, i have put a live feed to the pump, and it works, but any one got any diagrams of this
also
there is no spark, new coil, everything seems to be earthed correctly, anyone one what voltages should be going to the coil, and at what pins
djony
I had the same problem but on a XU9J4. The crankshaft position sensor wasn't working.
blessed6383
it may be the cas but these just work on a magnetic basis so failer should occur that often
would be interested if you figure this one out as have a similar problem on my Mi16
Did you see the car it came from? Thats the first question I;ve got to ask then you can work from there as I know most people's idea of wiring is horiffic
stuart1298
nah, got the loom of a bloke on here, from ireland, it seems like a decent job, i've sent him an email, there is a random wire that i cant work out where it goes, so fingers crossed its an earth or live, gonna get the multi meter and power probe on it at the weekend, fingers crossed i solve the problem
stuart1298
its all sorted, there was a sneaky little wire that had to be connected to a perm live, got the probe on it, put an earth down it, nothing, put a live down it, n click click click, relays done what there meant to, and it started straight up, so shes finaly running, loads to do now tho.....
