Paul Smith
Hub Spreader
Paul Smith
Hi I was just wondering if you definitely need a hub spreader to get the dampers out of the front hubs or whether there was another way?
just a sump plug key or an allen key :)
often enough they just slide off without though.
Edited by welshpug
Soft hide mallet will normally knock the upright down off the damper without too much hassle.
Stevo309
Agree with the above although when reluctant I have found that driving a small chisel/bolster into the gap with the pinch bolt removed helps a lot
pugpete1108
I find a whack from a club hammer works perfectly well
