TheHawk
Gti Bootlid On A 205 Gr
TheHawk
Hi there guys just a quick one will a gti boot fit on my 205 GR as i have been offered one at a very good price!
GLPoomobile
What do you think might be different about the two?
That's not supposed to be an arsehole reply, but rather than give you a simple yes or no, have a think about it for a second :)
TheHawk
Do i understand i thought the gti might be a bit narrower than the gr coz its 4 door. But im guessing it would fit!!!
TheHawk
**I do understand**
DamirGTI
In fact , there is "a difference" :) .. not the bootlid itself but the bootlid hinges - Ph1 has one hole mount hinges , while Ph2 has two (for the bolts ..) .. so , make sure you take the bootlid along with the hinges .. in order to save yourself a bother of drilling if you end up with Ph1/Ph2 mix ...
Damir :D
Edited by DamirGTI
GLPoomobile
Excellent point Damir :) And I'm ashamed that I didn't think of that when trying to encourage TheHawk to think about it, since I've been there myself. On my old Ph2 GTI the bootlid had 2 bolts per hinge, and I then picked up a replacement boot that turned out to only have 1 bolt per hinge. But interestingly, the hinge had slightly indented markings on it corresponding to the 2 holes on the later bootlid. I drilled new holes (slightly oversized to allow some adjustment) and all was well again.
TheHawk
Cheers for your help guys im new to the car game my 205 is my first car so bare with me i am still learning!!
GLPoomobile
You've come to the right place :D
Forgive me if my original post came across as patronising. Sometimes it's better to encourage a little bit of lateral thinking rather than spoon feeding a simple answer.
