steve@cornwall
Brave Or Stupid?
allye
Standard Rallye beam (base model) with some spax shocks, will be on a rebuilt 1.6 GTI one in the new year. Will prop cut the just the lip off or something, may do the same on the front. Solve it once and for all.
Ali
steve@cornwall
Ali
not to this extreme,then? :huh:
My "improved method" didn't work out so the n/s was done with the same method. I would recommend drilling all the holes for fixings before cutting - whilst it has more strength.
Et Voila! without TSWs
Front ride height to be raised and wheels painted and job will be done
allye
Its not needed to cut that much out is it? You'v done a very tidy job though, with the entire car as well, you really would never know!
What have you done about stopping rusting on the newely cut edges?
Cheers, Ali
steve@cornwall
Cheers, Ali
I think that's the least cutting needed to fit the gti arches. Good old smooth hammerite should take care of the rust proofing. It wasn't a difficult decision to butcher a base shell, I'd be more wary with a Rallye - love 'em with euro Rallye arches, though :huh:
allye
Indeed, this is my dilemma I don't want to make a hash of it and ruin the original (very tidy rot free) shell! Although Jonnygoodhand did cut his up. The Rallye arches do look great and a bit silly without cutting the arch underneath. Think I might just go for it and man up!
I half considered just getting some compmotive TH wheels in 5.5j so they may fit under, but I can't spend that much on wheels and I really like the S2 steels.
Cheers, Ali
SurGie
Good job.
Is it me or does the back wheel look like its sticking out and the arch trim look not quite right ?
jonnygoodhand
... Although Jonnygoodhand did cut his up.
I did, but I'm not sure I'd do it again. When I put the car back on 106 S1 Rallye wheels (5.5J), it really felt alive and I'd be tempted to stick with the standard shell/slim wheel combination in the future.
DaveW
Ali
I think that should be ok tbh its quite stiff with the gti stuff.
Leet205
Good work Steve, but get a Gti rear valance fitted!!
Rich_p
Was this the white one that was slightly lowered and on white pepperpots?
I really liked it before, it looked clean and simple.
steve@cornwall
That's the car, I liked it best in thart guise, too and it was fine for light use but wouldn't carry any sort of weight without rubbing the rear arches. When I removed the blue stripes from the sides the n/s had had paintwork upto the coachlines and new lines applied on top which left an unsightly ridge. There was also an "elastic" dent in the door that the trims splint quite effectively :) Some paint on the driver's door had recently started lifting also, leaving cherry red showing through - obviously a replacement s/h door. It's as much an economic decision TBH - spend hard cash on the 1.1 or use that cash to put fuel in the 1.9?
DaveW
Yeah looks good now :)
CallumCurwood
I could do with your advice. I need to do this to the front arches, how much would you surgest? I have rallye arches with 1900 wheels and lowered 40mm
Henry Yorke
Cheers, Ali
If you put discs on the back, the beam will be narrower. Alternatively, what about a Skip Brown negative camber kit. I ran 185/60/14 tyres on my XS that was stupidly low at the back with no catching problems
I could do with your advice. I need to do this to the front arches, how much would you sugest? I have rallye arches with 1900 wheels and lowered 40mm
I would trial fit up the arches and see how much you can afford to lose and chop that off.
SBC negative camber kit would likely make things worse rather than better, seeing as the way it is done involves widening the track slightly using longer stub axles and a spacer wedge between the trailing arm and caliper mounting bracket.
I'm interested in how that kit works, as unless I'm missing something all the wedge plate does is line up the caliper bracket, and there must be a wedge sleeve or something to alter the angle of the stub axle in relation to the arm to gain any negative?
boldy205
Dont forget Steve, it NEEDS a Gti rear Vallance. (Or however you spell it!)
Matt
allye
I will be getting a rebuilt beam of Anth next month so discs could be an option, what combination would that be? Disc brake parts on a 1.6 beam?
Disk parts on a 1.6 beam = 1.9 beam ;)
allye
What henry y talking about then!? As a 1.9 beam is wider!
