edbar
Rear Bumpstops
edbar
Should a 205 have rear bump stops like the 309's? My 205 hasn't got any on and wondered if that was normal?
Edd
yes it should have them :)
one-lady-owner
And if they don't and you have a fully laden car the wheels will scrub the arches!
Worse than that - with a 205 beam, it will rub through the fuel filler pipe if the O/S bump stop is missing...
one-lady-owner
Having heard that (for the first time!) I'm quite glad the only one missing on mine is the N/S!
edbar
Balls! Do they bolt on then? mines missing both!
Yes they bolt on, they are commonly missing as the steel cup rots out and then they drop off. About £8 each from Peugeot, a bit awkward to replace, easier if you can drop the beam off.
JRL
Mine was missing and the wheel rubbed the thin hose on the driverside what is that hose a vent or overfill? Like Tom said the metal cups rust away the hard bit is trying to get the rubber in the new cup I lubed it up with soap and used a screwdiver to push it in.
