jord294
Just Testing The Water Please
jord294
hi guys
i have a zero mileage mi16 d6c engine in my posession, and i'm contemplating selling it.
but only if i have interest will i advertise it in the 'for sale' section
so, as said, Zero Miles, Rebuilt to the following spec. Cast Iron Heavy duty re-bored block
Engine mount kit, crank reground, new bearings shells, oil pump, timing belt kit, sump gasket set , water pump, Piston rings. Fully assembled & painted black.
comes with fancy 8 branch exhaust manifold, inlet manifold and throttle body, clutch and flywheel
the rear mount i'll supply will have a new group n bush fitted
so, if your interested, please let me know
many thanks
boombang
Who rebuilt it and do you have a price in mind?
maturin23
"Zero miles" is rather disingenuous - the crank, rods, pistons and block are all 'used', plus you've not even mentioned the top end. Brand new head and valve gear?
It has to be described as 'zero miles since partial recondition'.
Not very helpful but I would have thought you'd have to offer a warranty to get decent money.
I'd value a rebuit engine with 2000 miles under its rings significantly higher than one that's not been run at all.
Edited by maturin23
I might be missing something here, but if it's an iron block, then it isn't a D6C engine - D6C is an alloy block XU9J4 non-CAT 1.9 Mi16 B)
jord294
sorry for my unclear description.
but what i have is similar to what is listed here
http://www.hiflowheads.co.uk/forsale/engines.php
if you speak to andy. he will give you the exact spec. my last conversation with him, he assured me it is a d6c engine
i wouldn't be asking anywhere near what they are, and remember it comes with manifolds etc
cheers
Edited by jord294
hcmini1989
cheers
Any pics ?.Wasnt this one of those low comp engines (brand new jobby) .But rebuilt into hi comp spec.Ebay it these motors fetch stupid money even when they`ve done 100k plus .
I'd look at the block to see if it's Alloy or Iron and this will clear up allot of things, If it's a Iron block then its not a D6C
And all blocks are std Iron, non are Heavy duty I'm afraid
Edited by Miles
jord294
definatly an alloy block
will post pics up as soon as i get some charge in the camera
Thats a relief, Makes it worth allot more
jord294
but unfortuneatly can't get a decent pic of the plate
anyway, here is a couple of pics
jord294
UPDATE
having spoke to the original builder of this engine, i can confirm that the engine was fully stripped, and was chemically cleaned before rebuild
so to make things more clearer. this engine has done
the head was also pressure tested, with the valves re-ground and new stem seals fitted
i've been told that the manifold is o/e (i thought they were cast :) )
a lot of money spent on new parts
so if you are genuinely interested, please let me know, then i will advertise properly in the appropriate section
thanks
Edited by jord294
boombang
Still wondering who rebuilt it?
Manifold is definately OE btw.
jord294
as i mentioned in previous post. it was built by http://www.hiflowheads.co.uk/
boombang
Not being picky, but you stated similar to the spec on their site rather than actually built by them - thanks for clarifying though.
I've had dealings in past with HFH so I'm no longer interested.
Guest
