DamirGTI
Decarbonizing Engine With Water
nost of the people on there had tried it on larger capacity carb engines
I doubt it would have much benefit on a small 4cyl injection engine
Somebody try it.......and post results!
DamirGTI
Dunno really :rolleyes: but theres loads of info regarding this if google a bit , and also on youtube ..
.. from what i've seen people done it on both carb and EFI engines , small and big ones ...
Damir :lol:
If you have ever dismantled an engine with a knackered head gasket that has been using water you will see the same effect, piston crowns and valves spotless having been "steam cleaned".
Same goes for any engine that uses water injection.
DamirGTI
Yes , certainly Tom :lol: did saw the cleaning effect after HG failure ...
But this somehow just seems wrong ! :rolleyes: "filling the intake with water" .. water injection is more refine/controlled process than simply pouring the water inside ..
... might try this once , though , will use some old carb jet and stick it inside the pipe and use that for water suction .
Damir B)
Minty Sauce
Rather than start a new topic I thought I would bump this.
Has anyone done it on there 205?
Looking through the spark plug holes my piston crowns are completely black.
pip470
Italian tune up
Minty Sauce
Italian tune up
Is that going to remove hard carbon deposits?
boldy205
They will be black after lots of use. Probably cause more problems loosening the dirt than leaving it there.
