justinv
[body_work] Fixing Her Up
justinv
The time has come and finally starting fixing some stuff on my 205, in the following days I will upload some pics,
Jobs to be done,
Clean whole engine bay - ( spend 4 hrs just to clean part of the bulkhead today )
Fix up and clean all loose connections
Brake system - Sorted
Coolant system - started taking it apart and replacing pipes with a BBM silicon set, and got rad back from a clean
Suspension - all new with front H&R springs
cleaning of surface rust under slam panel and under headlamps
Removing fuel pump and clean fuel tank and filters
Fixing back in the heater matrix ( done and tested now just connect it back up )
Replacing starter motor with another I have which does not fool about, for now !
This is all I can think of at the moment will sure add more to the list
tomcolinjones
pictures?
JRL
I will look forward to seeing the pics. Very satisfying and doesnt cost money to do those sort of jobs.
justinv
Yes will sort some pics out as they have to be low res will try upload some tomorrow
justinv
This is the first picture of the partly cleaned bulkhead
justinv
Another off day spent at the garage to continue the pending list,
Finished cleaning off the bulkhead removing all the wiring and washer bottle and more cleaning began.
Picture 1 - Clean Bulkhead
Picture 2 - Clean bulkhead
justinv
Picture 3 - Water dist block cleaned and fitted back
Picture 4 - Clearing of wiring and washer bottle and more cleaning
JRL
I found using an aluminium oxide disc on an angle grinder got rust off well. It must be good to see the red bulkhead again.
justinv
yeah never saw it that red as it was like that when i bought it and got worse :)
justinv
Had some free time and headed for the garage to continue cleaning the bay, Pics follow
Removed battery tray and took the tray and slam panel to the blasters, blasted etch primed, and primed ready for paint.
Continued to clean the engine bay and Trustaned the rusted area.
justinv
Bay before cleaning and treatment and after
Mart Pug
Good work mate - what did you use to clean the bulk head?
justinv
Just some computer cleaning aerosol found a box of it lying around in the garage and decided to use it :)
Mart Pug
Nice! Will have to remember that one! :)
justinv
He he to tell the truth my friend was clearing out his work van and all the extra unlisted supplies ended up in my garage and tought I will try this ' surface cleaner ' as it is called
:D
justinv
Another picture update,
Today cleaned and etch primed engine bay right hand side
removed and stripped bumper and valance ready for repair - s**t job fixed side arch to bumper with a whole silicon bottle !
justinv
Right hand side headlamp panel ready for wirebrushing
justinv
Update time, today masked up all the cleaned sanded and de rusted area etch primed and primed ready for paint,
Hopefully will have some time to continue tomorrow
justinv
Know this looks quite boring for you guys but here are a few more updates,
Right wing repaired and painted
justinv
Front rust treated under coated and sprayed
stuart
Looks good, just started doing the front end of my latest project but think its going to need a bit more than a wire brush to get to the same standard as yours...
