grantley1988
Gaz Coilovers
grantley1988
Weel the sun was out for once! So i thought i would take the wheels of the arches and clean and seal the car for winter. As i was scrubbing away, i could quite freely move the spring around. Both sides were like this.
So when i put the wheels back on and lowerd the car to the ground. I made sure i held the spring so they slid into the top cup correctly and when they compressed everything is fine.
Is this how they are meant to be?
Could be a stupid question but i thought i would ask!!!
It is if you're running the car a bit low, you can get helper springs if its an issue.
If they are loose at full droop with the wheel off the ground then it could be an mot failure so you either need to get helper springs as suggested by Mei or raise the locking collar (& car) so its in contact, even only lightly.
j_turnell
Slightly different but on Westfields i drill through the top collor that secures the spring each side and lockwire to hold them in place.
Yeah, you can do that on any car with springs that become loose at full droop & it can't fail the MOT for it because they are held in place so thats another option tbh.
Batfink
Its a bit of a bodge though. Its not expensive to get coilover springs that do the job.
