Paul Smith
Speedo Needle
Paul Smith
does the speedo needle on the 1989 205 1.6 gti just pull off?
j_turnell
Yup iirc, the black plastic part in the centre pops off seperately, then just gently prise it off.
Paul Smith
Cool,
Ive taken the speedo off and repaired my trip and now put it together. My next problem is the speedo doesn't seem to move very much or at the right speed. The cable is connected at the rear because it is moving just seems to not work very well.
Any idea of the best was to adjust the speedo. I tried driving and 30 and pushing the needle on but then it just stays at 30?
Paul Smith
Ok ive just had another play I have checked the cable it is working and is connected to the speedo dial fine but is not turning the needle at all ???
Paul Smith
anyone?
Paul Smith
Found the problem, The coil inside the speedo has snapped I have soldered it and seems ok, I am working the coil shape back in so fingers crossed at least we have movement on her now.
