peter
2.0 Turbo, With 1.9 Mi16 Crank?
peter
I know this has been coverd extensivly for the s16/2.0 mi16 but what would happen if this crank was fitted to the turbo engine?
with regards to CR etc
thanks!
It will increase the CR by close to a point. Probably of little use if you haven't got aftermarket management. You can gain more from a few psi increase in boost. Hardly seems worth the effort.
peter
I was only wondering as my 2.0 turbo needs a crank and i have a 1.9 one spare, but if it increases the CR too much your right there is little point. ill just put a standard one back in it.
thanks
