swordfish210
Fuse Ratings
swordfish210
Hey all, i'm just about to crack on making my loom but i could do with knowing the fuse ratings for the Horn, Washer pump and the wipers. Unfourtanatly i don't have the handbook so i can't check in there.
When I've made looms before, I've just temp wired stuff up with an ammetter in line to see what it draws. Then add something like 20% to give some leeway and there is your fuse.
Lan
91 onwards: Horn 30, windscreen wash wipe 25
89-91: Horn 25, windscreen wash wipe 25
swordfish210
Cheers Lan. Tom; i probably will do that eventually but for now i just want to get it in and working
what I can figure from the manual is that wipers and washers off fuse 3 which is 25A, horn from Fuse 8 which is a 30A.
mickie
i'd devo buy a multimeter if you're making a loom
swordfish210
I have 2 :o
