SurGie
What Other Spec Of 205 Has The Same Speedo ?
SurGie
I think i'll need another one because the rev counter is fooked, cheers.
th_CuteChewandGTSpeedo007.jpg.
Edited by SurGie
An XS of similar year?
Why is the rev counter fooked?
Is it not a wiring or power problem?
SurGie
Yes its the spring wire that links to the magnetic bit behind the rev arm, it springs round then goes through the plastic top cap to a wire and while i was soldering it because it was a little loose the spring wire snapped away from the plastic cap, i tried my best to rectify it with no luck. I think that is why the rev counter was originally intermittent because of this weak joint against the plastic cap where it looks like it got glued in when it was made.
I may need another one if the rec counter repairer's cant mend it...
dumbiron
Also seen them in some GR's and XL's although not all.
SurGie
Thanks, it seems like they are in more 205's than i thought they would be and if i cant get it repaired ill post a wanted add up.
BERTMAN
definently looks the same as a UK rallye one
allye
Same as all base models and Rallye, not XS as that has a similar to a GTI.
BERTMAN
all the base model ones ive seen have had a clock, instead of a rev counter?
dumbiron
not an ebay item number * cough * :lol:
200536034630
SurGie
Thanks, i have been searching the net and didnt find any around, although i was looking for the ph1 type.
That one looks like its the modern version but it is the same, im not sure if the wiring plugs would work the same & have the same fit though ?
kentish_lad
if you still havent found one i have one that im just about to strip out of a 1986 gr let me know fella
