cheesegrater
Camshafts Xu5ja
cheesegrater
Hi I've got a camshaft I want to put in sold as a fast road cam. Is there anyway of identifying them? I can't see anything obvious.
Thanks,
Tom.
j_turnell
Should be stamped on the dizzy end.
Usually something stamped on one end of the cam - Kent Cams are stamped something like KC PTxx for example.
cheesegrater
Can't see anything. The only markings I can find are on the shank a '2', '88', 8 in a circle and an 8 in a square. :lol:
Sounds standard then.
cheesegrater
One shall be having words....
The term fast road can mean anything, Drive a car quickly on the road and it's a fast road cam if you see my point, It's like all the Group 'N' or competition words, vasty misused to get more ££
cheesegrater
Yeah true but they did say it was a performance cam. So it sounds very much like its just a standard cam so no point in changing my cam then.
It could be a "fast road" cam thats been reground so it would still have the standard markings on the main part of the cam but those mentioned by Anthony & James will be on the distributor drive end.
Piper are BPXXX & Kent PT.
Who did the cam come from?
Pugrich
Did you measure the Valvelift, not the only important thing put can tell something and its easy to find out.
cheesegrater
I'll measure them up I think. What measurements am I looking for?
I'll give the ends of the shaft a clean up but I can't see anything obvious on there.
Thanks,
Tom.
Henry Yorke
As Graham as said, a lot of the LAD "Fast Road" cams appeared to be standard cams but were allegedly from a special French supplier who had them reground
cheesegrater
Ah ok, so if I get my verniers out and measure the lobes and compare them to my originals? I can't see any obvious markings on the end of the cams mind.
